imx6ul CSI can't disable csi_mclk
tony-tony
lm98714_data.sensor_clk = devm_clk_get(dev, "csi_mclk");
retval = of_property_read_u32(dev->of_node, "mclk",&lm98714_data.mclk);
retval = clk_set_rate(lm98714_data.sensor_clk, lm98714_data.mclk);
clk_prepare_enable(lm98714_data.sensor_clk);
clk_disable(lm98714_data.sensor_clk);
See the code show above, I find that after I disable the csi_mclk clk, the imx6ul port(CSI_MCLK) still create wave, I don't know how to disable this clk.
tony-tony
The root cause: imx6ul CSI clk enable/disable reg is CG0 bit of CCM_CCGR3 not CCGR2, the SPEC
has some issue to describe this reg.
tony-tony
tomfang
Hi Tony,
are there some APIs that can set CCM_CGCR3 register?
tony-tony
You can refer to clk-mx6ul.c file, and use memtool to check reg .
jimmychan
please try this:
clk_disable_unprepare(lm98714_data.sensor_clk);
tony-tony
Hi jimmychan:
 In fact, I have tried to use clk_disable(lm98714_data.sensor_clk); and clk_disable_unprepare(lm98714_data.sensor_clk); and use memtool to check the reg, after call "clk_disable" or "clk_disable_unprepare" ,the CCGR2 "csi_clk_enable" bit will become disable,but the wave still create.
