Months ago I've realized a firmware/hardware MKE02Z project using KDS v3.2 and Processor Expert. Now I'd need to migrate the whole project to MKE06Z (with CAN bus interface). From the point of view of the 64-pin compatibility everything goes well but how can I (painlessly) change the CPU component MKE02Z64VLH4 to MKE06Z64VLH4 as shown?
I've defined lot of PE components such as Timers, I2C, GPIO, and so on...
regards,
gaston
Solved! Go to Solution.
Hi gaston,
Have a look here: Switching the Microcontroller Package, Device and Family | MCU on Eclipse
Other related posts are: Switching Processor Package in Processor Expert
and Changing the CPU with Processor Expert
I hope this helps,
Erich
Hi gaston,
I hope this helps,
Erich
Erich, this is exactly what I needed!
Thank you very much,
gaston
