SDRAM/K80 timing
SDRAM/K80 timing
rickadolf
Has anyone used a Winbond mobile SDRAM with a K80? Is mobile SDRAM timing consistent from vendor to vendor or do I need to compare the timing specs of the K80 and the SDRAM (Winbond W987D6HBGX6 - 128mbit) to make sure they're compatible?
Rick
rickadolf
Winbond spec is attached.
Rick
Hui_Ma
I check your attached spec about SDRAM timing.
The Winbond W987D6HBGX6 - 128mbit should works with Kinetis K80 product.
Wish it helps.
Ma Hui
Hui_Ma
We don't have record to use Winbond W987D6HBGX6 - 128mbit with Kinetis K80 product.
Do you have the Winbond W987D6HBGX6 mobile SDRAM  datasheet? I could check this datasheet if it is compatible with K80 product.
Thank you for the attention.
Ma Hui
