We work with PN532 NFC Reader and we need change the Baud rate wich default is 115200 Kbps and we need put 19200 Kbps but in library we change and after turn on come back same 115200 Kbps how I set for forever definitely work in 19200Kbps
Some body can help us?
Hi Cleber Barbieri,
I am sorry, but the baud rate is fixed to 115200 out of reset, you may only change it with command of "SetSerialBaudRate". Please kindly refer to http://www.nxp.com/documents/user_manual/141520.pdf for more details.
Hope that helps,
Kan
