about MK22FN512's External bus clock
Question asked by andypeng on Jan 5, 2017
Latest reply on Jan 5, 2017 by Alice_Yang
   I use KSDK1.3.0 component library version set MK22FN512 clock system in KDS, found the external bus clock maximum is 30MHz, but if the kinetis component library version external bus clock maximum is 60MHz. this is what reason? I would like to work in KSDK1.3.0 component library version so that the external bus clock works at 60MHz, can you?
Thank you
Andy
