CW license with unknow error
paul_han
A basic version of CW:
Part Description: CodeWarrior Development Suite - Basic Edition, Annual Subscription, Floating License
is purchased and registered. A license.dat is generated and placed in the MCU directory. CW 10.7 has proceduced a unknown error,
Here is the detail:
Detail information for product "CodeWarrior for MCU" version "10.7.0.FSL_b06017"
status: "Unknown error with key BasicEditionMCU 10.5, LM_NOT_THIS_HOST.  "
License model: "class com.freescale.core.ide.license.flexlm.FlexlmActivate11"
Contact Email: licensing@freescale.com
Register URL: http://www.freescale.com/cwregister
Purchase URL: http://www.freescale.com/cwmcu10
FlexLM Eval Period: 15 day(s)
GTL Server: gtlsrvr.metrowerks.com
GTL Port: 80 (8,080)
Wants Host ID: true
License file path: C:\Freescale\CW MCU v10.7\MCU\license.dat
flexlmFileLocator: null
flexlmFile: ${MCU_TOOLS_HOME}/license.dat
License file URL: file:/C:/Freescale/CW MCU v10.7/eclipse/../MCU/license.dat
Error String: Unknown error with key BasicEditionMCU 10.5, LM_NOT_THIS_HOST.
Mandatory feature keys:
    BasicEditionMCU 10.5, status : Unknown error with key BasicEditionMCU, LM_NOT_THIS_HOST.
Alternate Keys:
(no keys)
LM_PATH=null
License file Content (C:\Freescale\CW MCU v10.7\MCU\license.dat):
 #CodeWarrior Development Suite - Basic Edition, Annual Subscription, Floating
#License - CodeWarrior for MCU Basic Edition (Windows - Eclipse) for Paul Han
#Software Account
SERVER this_host DISK_SERIAL_NUM=xxxxxxxx
VENDOR metrowks
USE_SERVER
INCREMENT BasicEditionMCU metrowks 10.5 04-jan-2018 1 xxxxxxxxxxxxx \
    VENDOR_STRING="CodeWarrior for MCU Basic Edition (Windows - \
    Eclipse)" DUP_GROUP=UH ISSUER="Freescale Semiconductor" \
    ISSUED=04-jan-2017 ck=116 SN="FSL - xxxxxxxx" TS_OK
Can someone help ASAP please.
Thanks.
Paul
ZhangJennie
You are welcome!
Jennie Zhang
paul_han
Great, It worked.
Thanks for your help,
Have a good weekend,
Paul Han
ZhangJennie
Hi Paul,
You use floating license. Please follow this doc to install floating license step by step
Step Byt Step Screenshot Guide Floating license FlexLM for CodeWarrior.pdf
Regarding the original download license file, you need Make the following changes to your license file.
TO: Your license server's host IP address, or your license server's host name
If this can not solve your problem, because this involved your private asset, please create a private ticket with your license.dat. the engineer for license will check it.
https://community.nxp.com/docs/DOC-329745
Jennie Zhang
paul_han
Hi Jennie,
Thanks for your reply.
We followed with the instruction and got most of license installed. There is a problem we have on the port used for the license. port 27000 (in the Server status tab the perform Status Enquiry returns the license info for NI Labview) is used. Can we use any port or has to be 27000? Is it possible to use a different port for the NCP licenses?
Paul
ZhangJennie
Yes, I ever used port 1700. It works fine on my side.
Jennie Zhang
