FRDM K64F giving \n\nOK\n\n as output instead of \r\nOK\r\n
oliviachristyva
I am interfacing FRDM K64F with Zigbee ETRX357. I am getting the output and my UART code is working but instead of the output \r\nOK\r\n for an AT\r transmitted i am getting \n\nOK\n\n. I cannot understand what is the reason.
Please help me if you have got any clues..
Olivia
oliviachristyva
Hi guys,
Just add these lines after you open your port.Because the IO_SERIAL_NON_BLOCKING which you enable at the time of opening a port is not working that was the issue.
setflag = IO_SERIAL_NON_BLOCKING;
ioctl(GSM_Port, IO_IOCTL_SERIAL_SET_FLAGS,&setflag);
Hope it helps someone.
Thanks and Regards,
Olivia
oliviachristyva
Hi guys,
Thanks and Regards,
Olivia
danielchen
Thank you for your update, Olivia
danielchen
Hi Olivia:
I think this is a terminal parse issue rather than an uart issue. I would suggest you detect and compare the signal with your scope first.
oliviachristyva
hi Daniel,
I am not getting the output through the terminal. I am just debugging and watching the variable in KDS. Does this has something to do with the translation flags in MQX.
Olivia
