Problem in "Periph_SDMMC" example code for LPC 43S67
arvindprasad
I built the periph_SDMMC code and selected my board LPC43s67, I set the memory configuration, I also set Debugging to SWD.
After all this i tried programming LPC43s67 it Programmed successfully once,
After that i tried debugging it again with same "periph_sdmmc"and other example projects also but now,
always error will come  Error " Debug failed. Cannot Halt Processor"
I am using LPC43s67
What should i do now?
Labels (4)
converse
Senior Contributor V
