How to flash bootloader to sabre lite board
hazal_pektas
Hi all, I am trying to boot sabre lite from SD card. At first, I have downloaded the default GuruCE images and saw that the board is working fine. Then I tried to flash my developed eboot.nb0 file with mfgtool, but the tool stopped working all the time. Therefore I've tried to flash the bootloader and the images via Ethernet as shown in "GuruCE Starting Guide.pdf" but I had the error:OEMReportError 0xFFFFFFF7, BL_IMAGE_TYPE_UNKNOWN. I am using Adeneo BSP on WEC2013. How can I flash the bootloader developed with Adeneo BSP? Thanks in advance.
gary_bisson
Senior Contributor III
Is your eboot supposed to be flashed on NOR or SDcard? Note that by default the Sabre-Lite boots only from NOR.
Please ask your BSP provider for more information (GuruCE or Witekio).
Gary
hazal_pektas
Thanks I solved the problem. I tried the sb_loader and it worked but mfgtool still has the problem.
