i.MX6ULL : Interface 32-bit LPDDR2 memory with processor
sunildhaduk
We want to interface 32-bit LPDDR2 (4Gb) eMCP memory with i.MX6ULL processor.
But i.MX6ULL has only 16-bit memory controller.
Could you please let me know where to terminate unused DQ31-DQ16 data line of LPDDR2 memory and other related control pins (Mask and Data Strobe)?
If we don't connect DQ31-DQ16 data lines of memory than can we still able to use full LPDDR2 memory space (4Gb)?
Hi Sunil
please check below link with similar issue
Solved: 32 bit LPDDR2 component with a 16bit controller - Community Forums
