Where you can find the device I / O Signal Description and Input Multiplexing Tables (Excel file) to SAC57D54N
stanislavsafron
The document SAC57D54H, Rev. 5 05/2016 in Section 9.1 Package pinouts and signal deskriptions Fort package pinouts and signal descriptions, refer to the Reference Manual.
The document SAC57D54H Reference The manual is recommended:
The I / O Signal Description Table contains information on pins / balls of this device. See
the device I / O Signal Description and Input Multiplexing Tables (Excel file) attached to
this document. Locate the paperclip symbol on the left side of the PDF window, and click
it. Double-click on the Excel file to open it and select the I / O Signal Table tab.
Question: Where can I find the device I / O Signal Description and Input Multiplexing Tables
(Excel file) for SAC57D54N.
Sincerely, SFS1946.
martin_kovar
I/O signal description file is part of reference manual. Please look at picture below:
I am also attaching it to this post.
Martin
