Is this an MKL03Z8VFG4?
PeterK
Just recently I ordered some MKL03Z8VFG4s from a distributor. Having arrived, and unpacking, I realized that I had been sent some ATMEL-something chips and I returned them. Now the replacement chips have arrived. I assume that they are the right ones this time, but want to make sure.
I Guess I lost a little confidence in the distributor.
Packaging is QFN-16 and the chips are quite small, 3mmx3mm. It SEEMS like the marking/mask is "M3T4AABJ". But I am not 100% sure. The device datasheet has no information on chip markings/masks. Likewise the family datasheet and the latest ERRATA (1N86k).
I just want to verify, that I got the right chips.
Any help would be appreciated.
  Peter K
MarMi
Hi Peter,
I have just look at my MKL03Z8VFG4 samples and can confirm that size 3mmx3mm and M3T4AABJ marking are correct.
Martin M.
PeterK
Thank you for replying, Martin.
That solved my specific immediate need.
In general, I wonder where that information is kept.
Thanks again,
  Peter K
MarMi
Hi Peter,
Martin M.
