Good morning,
I haven't found the place where to ask this question so I put it here by now.
I've a design using the NXP device TDA8954TH, the problem is that when I change from mute to Standby I get a pop noise in the output. Looking in the datasheet I have found the way to avoy it when the device is turned ON, but this circuit doesn't avoid the pop noise when is turned off.
Any received help would be gratefull.
