How to build Ltib with hard float
zhenghuyu
when I build ltib with setting -mfloat-abi=hard  in config, I get the error msg: -mfloat-abi=soft and -mfloat-abi=hard may not be used together.
so how to build ltib with hard float
Hi zhenghu
one can follow attached document from ltib note i.MX has not fpu, only neon.
zhenghuyu
I can not find where the flag  -mfloat-abi=soft has been set。I only set the c compile flag   -mfloat-abi=hard
and the u-boot builds successfully  but the kernel doesn't and show the error message
zhenghuyu
Can you give me some more detail instrutions?
