(our development environment : MCU :MPC5604B, Compiler :windriver diab 5.5.1) We have problem that when we compile project code from wind river diab 5.5.1 compiler compiler has some errors (for example assembly error) we think that the reason are makefile configuration or start up code problem (windriver doesn't understand code warrior start up code) if you have experience that codewarrior compiler convert to wind river diab 5.5.1 compiler (for example you have changed compiler configuration form code warrior eclipse program (named :CW for MCU V10.7) please advise about our problem thank you for your reading time
unfortunately, there is no way, how to automatically convert project from CodeWarrior to WidRiver Diab compiler. From my point of view you should create linker file and startup manually for diab compiler. CodeWarrior linker and startup could be used as a base for your project.
Maybe you could try to contact WindRiver support directly and try to get some example project from them.
