The opensda is designed for the on board K20, not for K64 in the FRDM-K64, after the K20 have the opesda code, it will be the opensda debugger or JLINK debugger(with jlink firmware).
So, please install the opensda on the K20 in the FRDM-K64, the on board opensda debugger can download the K64 code to the K64.
Wish it helps you!
If you still have any problem, please let us know. Have a great day, Kerry
----------------------------------------------------------------------------------------------------------------------- Note: If this post answers your question, please click the Correct Answer button. Thank you! -----------------------------------------------------------------------------------------------------------------------
Hi Roy,
Wish it helps you!
Kerry
