Dear All,
Can we work with this resolution 13848 x 104 for camera ?
Both are dividable by 8 which is required for IPU, so I think, it should work right ?
Thanks for your support.
Titus S.
Solved! Go to Solution.
Hi Titus
supported camera resolutions are described in sect.37.1.2.1.1 Camera Ports
i.MX6DQ Reference Manual
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
"Frame size: up to 8192 x 4096 pixels"
Hi Titus
