Hello Mahesh,
I checked you also ask the same question on salesforce, 00098055
I replyed you on that system. Please check it .
Alice
Thanks for your response.
I am getting a error message saying "7-Zip: Data error" when i try to install IDE from purchased USB flash drive. Am i making any mistake while installing or anything other than that? Screenshot is attached.
Thanks in advance,
Sathishkumar.
Hello Sathishkumar.
Do you received the email from salesforce?
The email is "
Dear Sathish Kumar, What about your system , there both have offline installer and online version.
For example , if your system is Windowns, please download it at here :
https://nxp.flexnetoperations.com/control/frse/download?agree=Accept&element=7954517
If other system, there also the related version .
If still have any question , please contact me without any hesitate.
From the error , does it a compressed file ?
Do you want to install the CW10.6 IDE ? If yes , please refer to the email i have send you , also past it on above.
And i recommend you use the latest version of CW10.7, it update all of the patch and fix some bugs . Also can use your
License .
Hope it helps
Alice
