./ltib -m config error:
making filesystem image file
staging directory is /home/work/ltib_source/ltib/rootfs.tmp
find: `./opt/syslog': Permission denied
find: `./opt/historycali': Permission denied
removing the boot directory and files
removing man files and directories
removing info files
removing /usr/share/locale directory
removing /usr/man directory
removing static libraries
removing target rpm database
stripping binaries and libraries
Filesystem stats, including padding:
Total size = 75024k
Total number of files = 1748
sh: 21: mkfs.jffs2: not found
Died at ./ltib line 603, <> line 764.
traceback:
main:603
Started: Wed Dec 14 18:28:44 2016
Ended: Wed Dec 14 18:29:08 2016
Elapsed: 24 seconds
Build Failed
Exiting on error or interrupt
please check that ltib was not installed as the super user to avoid issues
with access permissions. Refer to AN3875
http://www.nxp.com/assets/documents/data/en/application-notes/AN3875.pdf
