LPCScrypt and Keil ULINK2
enzofaffa
Hello, is it possible to program an ARM LPC43S3X by a ULINK2 programmer using the JTAG interface by means of LPCScrypt?
I managed to perform a programming by command line with the "crt_emu_cm_redlink" tool and ULINK2, but I'm looking for a n alternative stand-alone tool (I don't want to have LPCXpresso installed)
TY
Tags (3)
lpcxpresso_supp
No - LPCScrypt communicates with the target using VCOM over USB.  If your target board support DFU boot, then LPCScrypt can boot and program any internal flash devices or a Supported SPIFI flash.
This is fully described in the LPCScrypt documentation.
Yours,
LPCXpresso Support
enzofaffa
Thank you.
I obviously read the documentation and spent time to try to understand, but I was a bit confusing about USB...in my mind it was the USB communication between host PC and ULINK2, so my post to this forum.
Now I definitely understand that USB you're talking about is a way to access the MCU itself (that is, alternative to JTAG).
Do you have any clue about a tool different than LPCScrypt to achieve my needing?
Thanks again and in advantage
Enzo
