Common mode choke for TJA1100
akhilk
In the "TJA1100 Customer Evaluation Board - User Guide" it is recommended to use a common mode choke,ACT45L-101-2P in the MDI section. But that part number is not active now. So could you please suggest any other alternate part number for this?
niteshsahay
Hi Akhil
You can use ACT45L-201-2P-TL000 part as i have used the same for my design.
Nitesh
akhilk
Thank you Nitesh.
The difference between the two parts is the inductance value. That will not create any problem, right?
