My Sensor has 81 210 w 68 printed in it and its used with a 104 cap in parallel. What does the 68 stand for and what is the cap needed for?
michaelschuett
Can it be replace with other endnumber Units?
TomasVaverka
Hi Michael,
68 is just the production date. The first number is the year, the second number the month. So it is a sensor definitely from August, but the year could be 2016, 2006 or 1996… It can be replaced by a sensor with another number. What has to be the same is “81 210”.
Regarding the cap, I am not sure. For using this sensor the cap is not needed, so I guess it is application related.
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct". Thank you.
