I would like to amend the dhcp, how to do it?
qiubin2012
CPU:IMX6S   Kernel:Linux3.0.35
The board is powered on and configured with static IP. I would like to amend the dhcp, how to do it?
Tags (3)
gusarambula
Hello彬 丘,
You may edit the IP configuration on the kernel boot arguments.
You can see the options available on Table 6 (Kernel Boot Parameters) of the i.MX 6Dual/6Quad SABRE-SD Linux Release Notes.
The parameter would be ip and you can set it to ip = dhcp.
I hope this information helps!
