imx6 RGMII RX interface voltage too low
Question asked by Andy Huang on Dec 8, 2016
Latest reply on Dec 14, 2016 by Andy Huang
Hi ,
   We have a imx6solo custom board and use RGMII + marvell 3.3v phy .
Our circuit is     RGMII RX pins + level shifter + marvell phy
                          RGMII TX pins + level shifter + marvell phy
In this situation ,  imx6 tx packets are ok,  but RX pins voltage will drop to 2.0v.
And then we remove level shifter ,   marvell tx come out correct 3.3v  after measuring.
In the end , we wired marvell tx + imx6 rx RGMII directly ,  but the voltage is still drop to 2.0v.
We try our all  RX DSE and PUS combination but no help.
Do you have any idea to debug this ?
Here is our pin defination.
pinctrl_enet: enetgrp {
fsl,pins = <
MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0
MX6QDL_PAD_KEY_COL2__ENET_MDC 0x1b0b0
MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x1b0b0
MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x1b0b0
MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x1b0b0
MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x1b0b0
MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x1b0b0
MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x1b0b0
MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x1b0b0
MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b0b0
MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b0b0
MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b0b0
MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b0b0
MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b0b0
MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b0b0
MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8
Best,
Andy
