Pins 2.0 assignment issues for MCIMX7D7DVK10SC
mattdavis
I have encountered errors configuring MCIMX7D7DVK10SC using Pins 2.0
Pin assignment issues:
      AH01 - VSS-088 (Other VSS pins are X'ed out, should this be X'ed out as well?)
      W27 - should be DRAM_DATA16
      Y28 - should be DRAM_DATA19
      AA26 - should be DRAM_DATA20
      AB26 - should be DRAM_DATA21
      AB27 - should be DRAM_DATA22
      AB28 - should be DRAM_DATA23
Power group issue:
      Power group ADC2_VDDA_1P8 doesn't exist for the 12x12 package
I have attached a .mex file with these pins selected. The values shown do not match the datasheet.
What is the proper channel to request a fix for these issues?
Thank you.
Original Attachment has been moved to: MCIMX7D7DVK10SC---errors.mex.zip
Yuri
  i.MX Pins Tool 2 is under reconstruction now regarding i.MX7 configurations.
Please try it later. Nevertheless, I will forward Your information to the team for
correction.  IMX7 Datasheet is correct.
Yuri.
mattdavis
Hi Yuri,
Do you plan to fix these errors any time soon?
Thank you,
Matt
Sent from my iPhone
markruthenbeck
Matt,
The current tool download has this fixed. Thank you for reporting this bug.
mark
mattdavis
Thanks Mark,
How do I get these changes? Do I need to download and reinstall the tool again? Is there a version that I can reference to verify that I have the latest bug fixes?
Matt
markruthenbeck
Matt,
You can update the tool without a re-install. Please download and install the update and patch which can be found at Pins Tool for i.MX Application Processors|NXP
mark
Yuri
yes, of course.
~Yuri.
