MPXM2010GS and MPXM2202GS with barbed port
d_song
We use MPXM2010GS and MPXM2202GS. Both sensors do not have barb on the pressure port, which cause the tubing to disconnect very easily. Do you have the exact same sensors (spec/profile/footprint) that come with barbed port?The datasheet does show some barbed versions, but they are not drop-in replacements.
Labels (2)
TomasVaverka
Hi Dennis,
No. The only possibility is using Unibody or SOP packages with barbed ports as shown in the datasheet.
Tomas
