can any one help me to calibrate the 3 axis accelerator. I am using FXLN8372QR1
Hello Amith,
Thank you for writing.
The simplest offset calibration method consists of placing the board on a flat surface so that X is at 0g, Y is at 0g and Z is at +1g. 16 samples are recorded and then averaged. The known sensitivity needs to be subtracted from the +1g reading to calculate an assumed 0g offset value for Z.
Please find more detailed information at the document below:
FXLN8371Q - Bare metal example project
I hope you find useful this information.
David
Hi David,
Thanks for your reply, the contents you shared was useful.
Thank You
Amith
