Make device as OEM Production to use JTag Password
jaejynshin
Hello Expert
I programmed the "Life cycle slot" of UTEST area in order to make my device to OEM Production mode.
[before]
[After (wanted)]
After some trials, my device got unlimited reset even if I detached the JTag debugger.
How can I check if the Life Cycle went to OEM Productin successfully ?
And why my device got endless reset even if without JTag debugger ?
The registers of before programming the UTEST is like below
[Register]
[JTAG Password in UTEST]
Thank you
Jaejyn
petervlna
I have created and tested lauterbach script for OEM production life cycle setting.
Peter
tianyuliu
How did you modify "Life cycle slot" of UTEST areaWhat software do you use? Could you please tell me.
Thank you
petervlna
I do not use any SW to modify it. I have full understanding on how to create DCF records as I am daily working with them.
But for you will be much easier to use SW we have created to ease customer works with DCF:
https://community.nxp.com/docs/DOC-335523
Peter
tianyuliu
I've solved the problem, but thank you all the same.
petervlna
Peter
petervlna
First of all specify device you are using.
Peter
jaejynshin
Oh, Sorry for it. I am using MPC5777C
petervlna
I will prepare Lauterbach  cmm script for OEM.
As i am not today in office I will upload it this week.
Peter
