Turn-on Time to First I2C Use for NT3H2111
Question asked by Tony Garland on Dec 5, 2016
Latest reply on Dec 12, 2016 by Jorge_Gonzalez
Branched to a new discussion
  • I'm using the NTAG I2C Plus (NT3H2111) in an application where we are switching the power to the I2C portion of the chip--turning the chip off to save power except when there is NFC activity.  I've looked at the spec sheet and related documents (application note, I2C usage guide), but I can't seem to find a spec which gives the turn-on delay for the part. How much time is required for the I2C portion of the chip to be ready to respond to I2C commands after power is initially supplied to VCC?  In other words, after supplying power to VCC, what is the soonest that we can expect to be able to use I2C and get an ACK back from the chip?  I'm using 1 millisecond at the moment, but I suspect that is considerably longer than is really required. Rather than experimenting to determine an ad-hoc value, I'd prefer to use a value from a spec.
  • nfc nt3h2111 reset timing
