OV5640 Interfacing to LPC4357
sudheerkumardor
Hi every one,
   I am trying to interface 0V5640 camera sensor with LPC4357. I am able to communicate with the sensor using SCCB(i2c). I  just want to capture the JPG image, i did the required configurations to capture image(DVP). Even i did configurations for DVP it is still giving output in MIPI lanes only. can any one suggest required configurations to capture the data.
weidong_sun
Hello sudheer,
    On LPC4357, there are no MIPI-CSI2 & CSI(camer sensor interface) interface for recieving camera data, so you can't connect OV5640 with MIPI-CSI2 interface to LPC4357 directly, so your application is spectial, about hardware connections, you can evaluate following advice:
Then you can get 1 Frame picture with JPG format through USB port in software!
Hope above advice can help you!
Weidong
