AN606 receiver
Question asked by Matt findlow on Dec 4, 2016
Latest reply on Dec 5, 2016 by LPP
Hi,  I am building a VHF receiver on 120.55Mhz using AN606. The receiver is used to detect the carrier wave only, so I will be using the RSSI as a carrier detect.  I have no use for audio out, and want to dispense with  unnecessary components between the IF limiter/Quadrature detector and Audio out.  Can you please recommend what to do with pins 14, 13, 12, 11, 10, and 7, 8 to achieve minimum power consumption,  minimum component count, and maintain the integrity of the RSSI.  Regards Matt Findlow.
