MPC5748G: How can I check RxD signal of Flexray?
boyoungmun
I would like to check and see the waveform for RxD signal of FlexRay in oscilloscope. How can I check it?
Is it possible to connect RxD port to oscilloscope?
And I can see the FR_DBG port in schematics, is it used for check the flexray signal?
If yes, how can I connect the FR_DBG port for debug?  Is it need to special tool(e.g freemaster or CANoe) or not?
Boyoung.
lukaszadrapa
yes, you can simply connect RXD to oscilloscope. Debug strobe signals are internal Flexray signals routed to those pins, so they can be observed outside using oscilloscope...
Lukas
