I want to achieve the reset in the programe interrupt
Reset has four sources on the LPC2300: the RESET pin, the Watchdog Reset, Power On Reset (POR) and the Brown Out Detection circuit (BOD) (Section 3.4 “Reset” of the LPC23XX User manual).
So, to do a software reset, you could set the watchdog with a small timeout value, then go into an infinite loop.
Hope this will be useful for you.
Best regards!
/Carlos
