I've realised that I said .kds file when i meant .wsd file, sorry about that :smileysilly:
Hi Lex,
.wsd file is not need to import KDS project.
- goto main menu - FIle - Import - General - Existing Projects into Workspace
- select directory and the project from kds subfolder
Alternatively, you can also clone the project and create standalone project in KDS workspace using
- main menu - File - New - Kinetis SDK 2.x Project
- select SDK path
- select Boards - {board} - Examples - {example}
For this action you need latest version of New Project wizard from KDS update site. This feature also requires some metadata in SDK package, so might not be available for all SDK packages yet.
Marek
Hiya Marek
Thanks very much for your advice, I checked and KDS is selected in the toolchain section. To be sure, I selected all toolchains and re-downloaded the SDK, but still within my KDS folder I have a .cproject and .project file, as well as a 'settings' folder containing some .launch files and a .ld file. Do you have any idea why specifically the .kds file has been omitted? Thanks again for your help!
Lex
Hi Lex,
double check selection of the toolchain in your configuration. In case you did not select KDS, the example projects for this tollchain will not be included.
Marek
