FCCU ,MPC5744P
FCCU ,MPC5744P
deepikahk
How to make FCCU to fall into Fault state...??Because i want to check F_FFRR ( FCCU failure to react reset) in DES register
petervlna
And here is my example demonstrating FOSU reset.
Just copy it and you will trigger RGM.DES_FFRR
Peter
petervlna
You can use Fake fault inject via Noncritical Fault Fake (FCCU_NCFF) to trigger fault.
Enable the fault in FFCU_NCFEx register and set no reaction on this fault in NCFS_CFGx register. Then inject the fault.
Peter
deepikahk
Do i need to initialize FCCU_CTRL,FCCU_CTRLK registers and all ??
petervlna
If you want to get into config state - YES.
And you must go to config state to configure FCCU.
Peter
