USB MIDI Host
USB MIDI Host
bonzo
I'm looking for any help with implementing a USB Host MIDI on a Kinetis MCU.
The KSDK only supports audio data.  I need MIDI data which uses bulk endpoints and has lower bandwidth.
I tried setting config.h defines to the proper subclass.  It will enumerate and read the data, but the parsing in the driver hangs in an endless loop  in the function "USB_HostAudioStreamSetInterface".
Has anyone been able to do this?
bonzo
Found a solution with uTasker.
bonzo
