POR configuration registers P1010
Question asked by Smirnov Alexey on Nov 19, 2016
Latest reply on Nov 29, 2016 by alexander.yakovlev
Hello.
Trying to make some simple design using this processor.
There are two ways to achieve POR configuration. One is to use pull-ups and pull-down resistors. Another is to use PLD (CPLD for example)
Can you please point me out to a simple scheme how can I use POR resistors and at the same time having other signals there during normal process operation.
For example during boot the pin IFC_AD_00/cfg_sys_pll_0 should configure cfg_sys_pll_0 using resistor. And after booting (READY/TRIG_OUT is set) it hould be IFC_AD_00.
Hope i am clear here.
Thank you and have a great day.
