Driver impedance of EIM interface ,RMII and MIPI.
takashitakahash
Dear community.
our customer has question below.
Could you tell me the output impedance of the EIM driver of i.MX6Solo ?
Also please tell me the driver impedance of Ethernet (RMII) and MIPI of i.MX6Solo ?
Thank you,
Best Regards.
T.Takahashi.
Labels (3)
Hi Takahashi
driver impedance can be found in IOMUX Chapter or RM descriptions ofregisters
IOMUXC_SW_PAD_CTL_PAD_XX for DSE field, please check
sect.36.4.235 Pad Control Register (IOMUXC_SW_PAD_CTL_PAD_EIM_DATA22)
sect.36.4.216 Pad Control Register (IOMUXC_SW_PAD_CTL_PAD_RGMII_TD0)
i.MX6DQ Reference Manual
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
Hi Takahashi
