Stuck when trying to put FCCU into config state
Question asked by jlim on Nov 16, 2016
Hi, I am using the MPC5744P microcontroller and Lauterbach for debugging. I am having an issue where FCCU is not able to transition to config state.
This happens only when I have the watch window open in TRACE32 to observe a variable and run the program after doing 'in target reset'. I have attached a file that contains my FCCU initialization function.
When I read the fault status registers before config state, I get the value 65536 for the  FCCU_NCF_S0 register indicating " System RAMs uncorrectable ECC error "
I greatly appreciate any help with this. Thank you.
Original Attachment has been moved to: FCCU_Initialization.c.zip
