I consider using T1024 in single clock mode, however on the T1024RDB Quick Start document, it's written that "In Single Clock mode, JTAG cannot work to connect CPU". Is this a limitation of development board or T1024? If this is valid for both of them, how could I program flash without u-boot in single clock mode?
Tuna
Mentioned Document: https://www.nxp.com/webapp/Download?colCode=T1024RDBQS&location=null&fasp=1&WT_TYPE=Quick%20Referenc...
Solved! Go to Solution.
This is limitation of the development board only.
