hi,
We are designing a custom board use imx7d chip.
Is the usb port must be use otg mode when I download my firmware use serial download mode?
If the usb host mode is work well ,we would use this mode ,then the pin USB_OTG1_ID is not required.
thanks.
best regards
yan2anfei
Solved! Go to Solution.
usb host mode works well.
