HELP! FreeMaster_SCI connection question
_weh___george
I have build a FreeMaster_SCI code with PE, but have some question when I tried to connect the PC, and the error show "Can not detect the board information! The communication will be paused. Error code:0x80000101(Response timeout.)"
Thanks foe your help!
Hello George
Which chip do you used ?
Do you used the UART to connect ? If yes, please check whether select the right one .
And there is a tutorial about how to use Freemaster  :
Tutorial: FreeMASTER Visualization and Run-Time Debugging | MCU on Eclipse
Hope it heps
Alice
