I cannot create a bareboard application with my new install of CodeWarrior 11.1.1 for ARM on my Ubuntu Linux system. The IDE starts, and I'm able to complete the Create new project dialog. I click Finish and the dialog stays there, and nothing is created.
Solved! Go to Solution.
I fixed the problem by uninstalling and reinstalling CodeWarrior. This was for a LS1043 MCU, making an ARMv8 bareboard application.
Hi william,
Thanks for your response, is good to hear the problem was fixed after reinstalling CodeWarrior.
Best Regards!
Carlos Mendoza
Technical Support Engineer
Hi William,
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
