MP3V5050V battery operation
Question asked by P Mo on Nov 10, 2016
Latest reply on Nov 23, 2016 by Tomas Vaverka
If the MP3V5050V is operated on a 3 Volt button cell/battery, will the output voltage for the pressure measurement change/decrease as the battery voltage decreases?
Should I use a voltage regulator in my circuit for the supply voltage to the MP3V5050V? If so will a switching regulator work or should I use a linear regulator ? Thank you.
Phil Morello
Electronic Engineer
Suspended Animation Inc.
714-914-0731
