Hi all:
I use imx6q, linux version is 3.14.52.
I want to play ".ts" media .
I use comman "gst-launch-1.0 filesrc location=test-0.ts typefind=true ! $capsfilter ! $demuxer_plugin ! queue max-size-time=0 ! $video_decoder_plugin ! $video_sink_plugin"
But play failed .
The debug message is as blew:
(gst-plugin-scanner:349): GLib-GObject-WARNING **: cannot register existing type 'GstImxCompositorPad'
(gst-plugin-scanner:349): GLib-CRITICAL **: g_once_init_leave: assertion 'result != 0' failed
[INFO] Product Info: i.MX6Q/D/S
ERROR: pipeline could not be constructed: syntax error.
How to fix this bug?
Hi sen
please try commands described in attached Linux Guide sect.7.3.13 MPEG TS.
