SWD_DIO pin alternate uses
Question asked by Paul Kafig on Nov 8, 2016
Latest reply on Nov 8, 2016 by Butcher
I'm currently using the SWD_DIO pin on my processor for programming. Once programmed, can the pin be changed to another function? I would like to also use the pin for an I2C port, which is an alternate function per the data sheet.
I believe the answer is yes, but wanted to be sure. Thank you.
