I use the M68DEMO908GB60 board. Need a sample code in C language to start. Could you share the link for the software and what CodeWarrior version should I use that support the NXP MC9S08GB60?  thanks
minhdang
ZhangJennie
Hi.
GB60 is ARCHIVED product which is no longer for new design recommendation.
both classic CW6.3 and eclipse CW10.7 can support GB60. but please note:
- CW6.3 doesn't support 64bit win7 platform but 10.7 does.
- because GB60 is very old product, nearly all the existing demo codes are based on CW6.3 but not CW10.7.
here is the link of CW6.3
CodeWarrior for Microcontrollers-Classic IDE|NXP
here is the link of CW10.7
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
here is demo code of GB60 demo board
M68DEMO908GB60 Software Files
GB60 modules demo code is attached.
Jennie Zhang
minhdang
Thanks Jennie and Alice,
The M68DEMO908GB60.zip sample code is in assembly language. I am looking for the sample code in C language.
Appreciate if you could point to the link with the sample code in C language.
ZhangJennie
HI Dang,
unfortunately we don't have the same C demo code M68DEMO908GB60.zip
However I found we have
http://cache.nxp.com/files/microcontrollers/doc/user_guide/HCS08QRUG.pdf
GB60 modules demo code is attached. I suggest you look it though, this will help you better understand HCS08 peripheral usage.
Best Regards.
Jennie
minhdang
Hello Jennie,
Thank for the info and the sample code. That what is looking for.
Minh Dang
ZhangJennie
Hi.
Jennie Zhang
minhdang
Hello Jennie
The <https://community.nxp.com/servlet/JiveServlet/download/2028-438392-849405-395441/M68DEMO908GB60.zip> M68DEMO908GB60.zip sample code is in assembly language. I am looking for the sample code in C language.
Hello minh,
You can use the lasted version of CWv10.7:
it supports this chip.
In CW , create one project with Processor Expert , there will be demo :
when create project select "Processor Expert":
For example the AsynchroSerial  demo :
Hope it helps
Alice
