How to enter console and login while booting with linux-mfgtool-initramfs?
linhdong
Dear everybody,
I'm trying to use fsl-image-mfgtool-initramfs to run small application on RAM by MFGTool but I don't know how to press Ctrl-C and login to linux initramfs to run my application manually.
In the attachment file is script for mfgtool to flash linux-mfgtool-initramfs to my imx6dl-sabresd board.
Could you please give me a suggestion for this problerm? thanks !
Original Attachment has been moved to: ucl2.xml.zip
b36401
Please follow these suggestions:
https://community.nxp.com/thread/301459
regarding to ramdisk as Kane suggested. It should help.
Victor
linhdong
Hi Kane Jiang,
Thanks for your reply. As your suggestion, we can flash rootfs.tar.bz into ramfs and run it directly, right?
I just want to test on ram without flash to eMMC. I have edited and changed to flash rootfs but it can't boot.
old :     <CMD state="BootStrap" type="load" file="fsl-image-mfgtool-initramfs-imx6dl.cpio.gz.u-boot" address="0x12C00000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD>
new:
    <CMD state="BootStrap" type="load" file="rootfs.tar.bz2" address="0x12C00000"
I don't know how to build rootfs.cpio.gz.u-boot.
jian_jiang
Hi linh dong,
I am sorry for misunderstanding your question, it may be correct for file="fsl-image-mfgtool-initramfs-imx6dl.cpio.gz.u-boot".
The following link has some useful information , but I understand that you may still having problems.
IMX6 - booting to a roofts on ramdisk (Boundary Sabre-lite)?
All the best
Kane Jiang
jian_jiang
Hi linh dong,
I think you may need to flash rootfs to login to the linux.
All the best
Kane Jiang
