Generating code with processor expert (KDS) and using it in IAR. Dont know how to disable the error. !!
Question asked by Volkan Coskun on Nov 6, 2016
Latest reply on Nov 20, 2016 by Alice_Yang
Hello I am trying to run the generated code for kl03z or kl17z on KDS using processor expert. That is sucessfully working and I get no error. However when I am trying to run it on IAR, I have to explicitly remove:"PE_low_level_init() in the main code! And then I can compile it sucessfully! However I don't really know if I am suppose to remove that since it says explicitly in the code that I should NOT do that ! Here is the code snippet :
/*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
PE_low_level_init();
The error I get :
Error[Li005]: no definition for "PE_low_level_init" [referenced from C:\Users\volkan163\workspace.kds\ .
I have submitted a picture that shows the error I get.
How can I solve this problem ? I want to compile the generated code without errors .
regards,
VC
