how to terminate PCT2075GV unused OS pin
enzoguerra
hello
can you please advise how to terminate PCT2075GV OS pin which will not b used
it's an open drain output pin; just want to be sure
regards
enzo
TomasVaverka
Hi Enzo,
You can leave the OS output unconnected (floating) if not used.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
